Lets start by most all my gauges was bad I replaced the fuel because it was the most important. if I turn my navi lights on the fuel gauge would read and tach would jump to 1000RPMS. As of lately I repowered and found out my heat horn was bad also. Since it is a important piece to not ruining a newly rebuilt engine I replaced it recently then when I turned on the navi lights the horn would chirp but it operated normal other than that one flaw. I since then replaced the tach and water pressure gauge, I was careful to rewire everything back as it was. I went out today as it was going to be a nice enough day to maybe put a few more hrs on the engine. went out to the garage went to trim the motor up and had no juice no lights came on when I turn the switch on or nothing. I was thinking I must have left the key on and the battery was dead tested the battery all was good. Found two loose wires best I can tell they are grounded to the Ground terminal of the fuse box but have no clue where they are suppose to go looks like lots of noodles under that dash wires ever where dont no whats up or down. But heres the kicker in order to trim the motor up the navi lights has to be on and the key switch to on position that is the only way anything will work. I thought about disconnecting evrything getting a manual and starting from scratch. any Thoughts?Sorry this is so long and drawn out but I had alot to say...
