Re: My Project Boat
The serial # is located on the tilt tube between the thumb screws as seen from inside the boat.
Thank you, I tried to look there but the motor is in the up position and I can't see it, I can see some writing but I need to lower the motor to see it, I guess I need to get a battery and see if the trim works to get the serial number, damn
start by grabbing the prop pull up and down and check flex in transom. you have your work cut out for you but i bet the motor will turn. it may be the lower unit that is frozen. you will need to drain the trim pump to lower the motor. all the wires will need attention inside the motor in order for it to have a spark at the plugs. i am restoring the same exact boat now and yours looks even nicer ! can you post more pics ? classicglastrons.com. ,fiberglassics.com and the old merc guys at johnsoldmercs.com. the motor and boat are most likely the orignal rig made between 64'-66'. take your time it's been sitting a long time
I tried to pull up and down on the prop but I didn't see any flex in the transom at all, the transom has been repaired, I can see a fiberglass fix on it. these links don't work: classicglastrons.com and johnsoldmerc.com don't exist, are you certain you got these links spelled correctly? You are right, the boat needs a lot of work but the hull is in great shape. I will try to post more pictures on my flickr account.
Pull the plugs, spray some wd-40 into the cylinders, let it sit a while, then a little light oil into the cylinders and manually turn the shaft with a wrench on the center bolt on the flywheel. Once you are certain the pistons move freely you can go with the starter and battery.
Thank you! I will try that.
I could not see the pictures, as flickr is filtered out
Very likely that motor is 2 cycle. If the prop doesn't turn, maybe the gearcase has trouble. That could stop the flywheel from turning as well. Remove the spark plugs and look for rust. Squirting oil into the cylinders is a good idea.
A standard automotive-type battery is the right kind to run that motor and work the trim as well.
Thanks for the tips. I will try those things. I totally new to boats so this project is a learning experience for me. It should be fun
This link should work to see pics of my motor--->
http://www.flickr.com/photos/tyler6357pics/sets/72157629483303707/show/ if it doesn't work it could be your computer settings.
