Trojan 270 Express
- Feb 25, 2012
- 4
I've got a 27' Trojan with a Merc 228 straight inboard - 1986. She runs great except for the fact that she slowly overheats at idle speed. Idle RPM is ~650. In an idle zone, I must shift to neutral and increase RPM to drop the temp and then resume forward motion. The raw seawater pump gets a new impeller yearly. The engine circulation pump has been replaced. The manifolds and risers were replaced years ago and are not showing any major corrosion - I pulled the starboard riser and looked. The hull strainer and sea **** are clean. I'm in fresh water, so barnacles hiding out deep in the passages is not a concern. The thermostat is new and is the recommended 140 degrees. I should also say that when coming off plane, the temp will skyrocket if you don't keep up the RPMs -- much more than the normal bump in temp for a raw water cooled straight inboard. I may be convincing myself that I need to replace the manifolds and risers, but just wanted to know if anyone else has had a similar situation. Thanks!
