fishfeatures
- Mar 29, 2011
- 743
johnson 89 60hp
Have been having trouble with getting a new to me powerhead idleing.. Have good spark , and compression is within range 120,113,120.
SO
I went ahead last nite and pulled the carbs apart, soaked them, ran wire through them and compressed air to finish off, then put them on today.
Now the darn thing won't start unless I choke it loads and won't keep going unless i choke it every2 secs ( this is on muffs not even in water)
I crank the engine and the pump is pulsing fuel out. all lines are new and no kinks, I think that by cleaning the carbs I have made my issue worse.
How is this possible?? I guess I'll pull them again is there any thing else I should do?
Oh Lync and sync done according to OMC manual and timing was ok 2 weeks ago when checked.
SO
