jslu
- Jul 31, 2010
- 74
1989 Mercury, 35 HP, SN# 0C120583
This Merc has the "square type" fuel pump.
I purchased a Merc rebuild kit, # 21-857005A, and proceeded until I discovered ambiguous instructions as to how to proceed.
This has to do with the two check valves.
In my factory Merc manual it shows each valve assy as being a 3 part assy, a rubber disc. a nylon disc and a nylon retainer.
The rebuild kit does not contain the rubber disc nor is it mentioined or shown in the rebuild instructions. Also it does not instruct to discard the rubber disc, only to discard the rubber retainer, if you have one. The valve assy is then shown as a 2 part assy, nylon disc and nylon retainer.
It appears to me that this pump has been rebuit before because it does have the nylon retainer, the rubber disc and the nylon disc. Frankly, it looks kind of odd to me.
I know there are a lot of smart folks out there on this forum.
HOW SHOULD I PROCEED???
Thanks,
John
Thanks,
John
