I have a 1994 Sea Ray 180 bow rider with a 4.3 MerCruiser and an Alpha One Gen II drive. While removing the old gimbal bearing I managed to chip off a piece of the housing in the space behind the bearing where the seal goes. I then patched the hole with J-B Stik Weld and sanded it smooth. Will this be a problem now or even sometime down the road? Does the housing have to be replaced or will it be ok? Thanks
Chipped Housing...
JB Weld Patch...
Chipped Housing...
JB Weld Patch...
