Will a 50 hp lower unit work on a 70 hp
G Greg3000 Cadet Joined Feb 16, 2012 Messages 27 Feb 20, 2012 #1 Will a 50 hp lower unit work on a 70 hp
BonairII Commander Joined Jun 7, 2011 Messages 2,727 Feb 20, 2012 #2 Re: Lower unit compatibility Might help a bit to add what yr/brand motor you have.
G Greg3000 Cadet Joined Feb 16, 2012 Messages 27 Feb 20, 2012 #3 Re: Lower unit compatibility BonairII said: Might help a bit to add what yr/brand motor you have. Click to expand... Mine is a 77 70 hp Johnson the other is a late 70's early 80's 50 hp Johnson shaft shift rod and splines are the same thanks for any help
