3.0 alpha 1 fit a 5.7 velvet drive?
Re: 3.0 alpha 1 fit a 5.7 velvet drive?
Probably Not...
badger32
how will i find out which prop to fit? its a v drive 10-17-004
Ayuh,.... Ya need to Measure the propshaft, 'n it's taper...
badger32
the length of it?
see alot of props for alpha of bravos but not listed any for velvet drive?
the length of it?
Ayuh,... That's because the Velvet drive is a Transmission, 'n Not an outdrive....
It's a small bit of an Inboard...
smokeonthewater
what he said
look for inboard props.... a word of warning.... sit down first.... they are quite a bit more expensive.
86 century
Ensign
You most likely wont find your prop by the eng or trans.
As said above you need to know shaft size.
steelespike
If you have a prop there should be a size number _ _ X _ _ also a manufacture number.
Its possible a boat model and brand may help.
badger32
will have a look tonight for prop size, found this chart, http://www.searay.com/boat_graphics/electronic_brochure/Company1729/1C1_25_74DEIP4PX0N.pdf
problem i have is i can never find much info on just searay ski ray will this boat be a 190sk i/b 350 magnum? see page 1 4th from bottom of link above prop size 13x13c? would add a photo but not sure how to? tried but not sure if it will work
steelespike
Found the boat in the nada price guide 92 Ski Ray 190 22ft 5.7 (250hp) 22 ft 2450.
I would bet that one of the Ski prop places may be able to identify your setup and prop
though the few places I checked didn't list the Ski ray.
It appears the Ski Ray 190 22ft 5.7was available in 92,93,94.
I'll bet it uses similar props to other 22ft 5/7 V drives.
If you can find the info on your prop it will eliminate the mystery.
badger32
ordered a 13x13 prop so will see how it tests in the water
cheers
