Hi guys: got a question for you all. Late last summer I bought the motor mentioned, put new oil in lower unit and had it on the lake for maybe an hour. Later I discovered it had a LOT of water in the oil. So naturally I want to fix that. I am guessing there is 3 seals. one behind prop, drive shaft, and shift rod. I know I will have to drop the lower unit but I guess my question is: can these seals be replaced without completely tearing the lower unit apart? In other words, I can pry the seals from the top ( example: around drive shaft pry it out, slide new seal down over shaft and re install ) was just wondering cause the thought of having to tear into the lower unit and pulling out gears and stuff sounds kinda scarey to me since i dont really know what I am doing
Thanks in advance for your help
Curtis
Curtis
