Reverend Brewmeister
- Feb 17, 2012
- 2
I am in the process of rebuilding a lower unit on a Johnson 1975 25hp motor. The motor was slipping out of gear and I have opened up and there is wear on the ears of the clutch dog. While researching the part numbers I noticed that the cradle that I took out of the unit has a different number than the one it is supposed to have. The part number listed for this unit is 302500. The actual part in the unit is 325014. Are these parts compatible? Could this be the cause of the slippage problem?
