fishnfool186
- Feb 16, 2012
- 5
Hi guys, first post here, so please be kind. Today I pulled my lower unit to change the waterpump and found that the bearing directly below the water pump base on the driveshaft had considerable play. (Oil looked normal when I changed it before the winter, after last use.) Turning the shaft felt like the bearing rollers were flat sided. How do I get into there and change the bearing? Does it involve a tear down of the whole lower unit just to get to the bearing?
Thanks in advance for any help I can get,
Jim
Jim
