How do you check the oil in your trim pump? (M/C 470, w/Alpha 1R) Do I check the oil when the outdrive is all the way down or all the way extended (up)? Also after several searches, I'm a little confused, should I use straight 30wt. oil or ATF?
Thanks in advance,
Larry
Thanks in advance,
Larry
