I've been reading these posts for a while now, and it seems like there are a lot of very knowledgeable people here...so this is my first post asking for help.
First-Setup: 2001 Mercury 200 EFI, oil injection removed-using premix 50:1.
Second-Problem: Starts on first turn every time. Idle out of boat ramp, then run WOT-5800 RPM for 20-30 miles. Get to my fishing spot, idle around for a bit to zero in on the fish, shut the motor down and fish for a couple of hours. When I'm ready to leave, motor starts right up, but will not run above 2800 RPM. I've limped in like this for a couple of miles, and it has kicked back to all cylinders and I've been able to run home WOT again. I've also limped for a little while, then shut motor off for a second, started back up, and been able to run back WOT. At no time have I gotten an alarm, and motor has not overheated.
Third-What has been done already: Replaced base gasket and exhaust plate gasket(both were leaking), replaced thermostats and temp sending units. Checked all fuel lines for leaks, fuel is fresh, fuel/water seperator is new. Both batteries and switch are new within the past year.
So....from what I've been reading, I could be looking at anything from a bad ground wire, a bad stator...or anything in between.
Where to start?
Any help is greatly appreciated.
Where to start?
