timotheius
- Feb 15, 2012
- 2
So I was working on my motor yesterday and managed to screw things up again. I had a charger hooked up to my battery and was charging it up. Without thinking, i decided to tilt the motor up. I pushed the "up" switch on the control to tilt the motor up, while the charger was still hooked up to the battery. Instantly the electric tilt stopped working. I realized what I did and immediately disconnected the charger. The motor will now trim down just fine, but won't tilt up. Electric trim works, electric tilt is now broke. Both were working perfectly fine earlier yesterday. I immediately thought it was a blown fuse, but could only find one fuse on the system and it was fine. Also, that fuse would disable both tilt and trim. Any help or ideas on what I may have done? Is there another fuse I don't know about? Or is the damage far worse? Motor is a 1999 Johnson 70hp 2 stroke. Any help would be much appreciated.
