  #1
Old September 18th, 2005, 04:55 PM
deputy00791 deputy00791 is offline
Default New boat owner need help withTilt motor on1982 3.8L OMC
I am looking for help with my tilt on my OMC. It is a 1982 3.8 Liter. My motor works fine except when it is in the full down position. When at 3/4 down it will go back up. When I try to bring it up when it is all the way down I only hear a "click".
  #2
Old September 18th, 2005, 04:58 PM
Don S's Avatar
Don S Don S is offline
Default Re: New boat owner need help withTilt motor on1982 3.8L OMC
You're going to need a lot more information than that if you want help. Things like year, model of OMC. They were around for 30 years, and technology did change in that period.
__________________
Don S.
Why is there never enough time to do it right the first time,
But always enough time to do it again?
Please, NO PM's (Private Messages) regarding boat/engine problems.
That is what these forums are for.
Only forum/moderator issues will be answered in PM's.
  #3
Old September 18th, 2005, 05:03 PM
thank you for the info. Liek I said I am new to forums
  #4
Old September 18th, 2005, 07:54 PM
whywhyzed whywhyzed is offline
Banned
I was having the exact same problem on my 3.8. I could usually get it to go by just bumping the switch. The cause is a dead spot on the armature, so I removed the tilt quadrant, bumped the tilt motor till it turned a few teeth of the gear, reinstalled the tilt quadrant.. voila.. 2 years later still working.If that doesn't do it, remove and rebuild, or replace the tilt motor. When you see where it lives, you'll wanna try the repositioning thing first.
  #5
Old September 19th, 2005, 06:04 AM
KaGee's Avatar
KaGee KaGee is offline
In addition, make sure you clean all electrical contacts on the solenoid, the plug and gound point.Make sure that your tilt gear box is not full of water.
__________________
If it were easy, any Caveman could do it.
  #6
Old September 19th, 2005, 06:11 AM
Phantom17 Phantom17 is offline
I found after reading my manual that R&R was rediculous. Spent alot of time trying to maneuver my arm past the gas tank under the engine to hold it up while twisting like a pretzel to start the screws.......then I removed the boot around the intermediate housing. It's right there. If you can't reach, remove the boot.Try the basics, bad connections etc, almost guaranteed that the motor is either dying, or the clutch pack assembly is full of water. Whatever you do, don't by a used one. I did and I still raise my drive by removing the quadrant gear and lifting / lowering the unit by hhand and re-installing the quadrant. Can't see the logic in a 25 year old boat of spending $200. on a motor that will fill up with water again and again.....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Some questions from a newbie boat motor owner (Johnson 70 VRO) sssports Johnson & Evinrude Outboards 11 January 10th, 2007 05:39 PM
New owner of old motor gasjake19 Mercury & Mariner Outboards 4 June 29th, 2006 12:28 PM
Need Input on New Boat Purchase... (First Time Boat Owner) TheChad Boat Topics and Questions (not engine topics) 10 June 2nd, 2005 05:22 PM
new boat owner oil looks milky boat runs but almost dead? Is this a sign the mot charriex2 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 August 2nd, 2004 06:13 PM
new boat owner no clue of age of boat & motor GREGH Johnson & Evinrude Outboards 15 September 8th, 2001 05:41 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
