Re: oil seal
That's the front cover seal. On the IL6 it can be a bit of a mission to replace. You need to remove the front engine mount. That means supporting the front of the engine while you do it. I would take the drive off while you do that, so as not to accidentally damage the coupler. Once you have the mount out of the way, remove the V-belt and crankshaft pulley. Then flick the old seal out and push a new one in. Check the seal surface on the pulley to ensure it's not grooved (the main reason the seals leak in the first place). Once you get it all back together, and before you put the drive back on, CHECK THE ENGINE ALIGNMENT!!!
The only special equipment needed is a crankshaft pulley puller.. (usually rentable form a local car parts shop)..
Good luck.
