sutor623
- May 23, 2011
- 4,087
Okay guys as some of you know I have been working with a Johnson 4hp 4R70E from 1970. Both of the motors that I have to work with have run hot. Luckily the cylinders are in great working order, even though it is apparent that these motors seem to have issues cooling the bottom cylinder. Here's the proof:
Anyway, in the next picture you can see how the water enters the block. The big hole on the upper right corner flows water to the top of the block, the little bitty hole right next to it, that I am pointing to flows water into the bottom of the block, and on the left about center of the motor there is a water return, that brings the water back out of the motor.
What I propose on doing is drilling the small lower block supply hole, out about 1/16th of an inch for two reasons. A) To permit more water flow to the lower end of the block, and B) to make sure that the little hole does not get clogged with debris, which is what I believe is the main issue with this engineered setup. Do you guys think this is a good idea, or do you think that it will alter the amount of water pressure to the top of the block too much? The difference in sizes is unreal. Has overheating been a problem for anyone with these little motors?
