Re: Outside flange joint repair.
I just did a small section on mine that i damaged taking it off. I just clamped a mold to the undamaged section of the flange, then I built up the new section until flush with the top of the hull using 2 layers of 1808 the first butted against the outside of the hull and fitting inside the missing section but not going over to the inside of the hull, and just stretching over the old section a tiny bit. The second layer is basically the same but a little longer so it over laps the old flange a little more and with the fibers just stretching onto the top of the hull. To finish it off I used 2 layers of 1 oz csm, each with a little more overlap than the last and this time wrapped aroung to the inside of the hull. This is where I went wrong, I didn't round off the inside top of the hull so I had a square corner and ended up with air bubbles that I have to fix tomorrow but it's really strong and looks good. Make it over sized and then sand it back flush, and don't forget to feather the edges of the flange.
Take a look at the pics in the last post in my rebuild thread, it's the before and after shots.
http://forums.iboats.com/showthread.php?t=507121&p=3633187&viewfull=1#post3633187
Now don't anyone go deleting this thread, I gotta copy all that over to my thread soon
PS
Thank god for the restore auto saved content on this forum, my computer crashed just after i added the smiley, while my mouse was hovering over the post reply button.
