I have a 1996 Wellcraft 1950SS Eclipse with a mercruiser 4.3L. I just recently purchased this boat and it had been sitting for 3 years. I have gotten everything squared away on the motor but i am having problems with the hydraulic pump leaking fluid at the top of the reservoir. Also, when i go to tilt the lower unit the switch will not actuate but when i put a screwdriver across the top bolts to bypass the solenoid it will work. I am assuming that the solenoids just need to be replaced. Finally, when i tilt the lower unit all the way down i have bluish tint fluid leaking where i put the ear muffs to start it on land. Could the leak just be a seal that needs to be replaced or do you think its just an expansion of too much fluid? Any tips?
