deputydawg
- Aug 29, 2004
- 1,607
Today got a call from a friend who pulled a good one last night. He took the drive apart and pulled the impeller out. I think it was a result of a 12 pack and showing off to a girlfriend.<br />He just had the impeller or water pump in the drive replaced in June from the local boat mechanic, so it is fairly new. It was not heating, was causing no problems. He had a seal on the output leaking a few drips of oil, and was replacing the seal. <br />The boat is an older mid to late 70's Imperial, 160hp mercruiser outdrive. Thee older model of drive with the loop on top of the top cover. "R" drive I think is what it would be called. Serial# 2615612 stamped on the drive.<br />Now the problem. He wants me to put the pump back together. Somewhere he found a new seal and gasket, but no new impeller. The one he took out has less than 20 hours on it and looks great. Only problem I am finding, what direction does it go in. <br />The fins are slightly curved. As you hold the plastic pump housing upside down does the curve go clockwise or counterclockwise? <br />Told him to go back to the mechanic and go ahead and replace it, but he still owes for the first one in June. They won't work on it until he pays up. ALso he is cheap and won't spend the $20 for a new one. <br />Any help would be appreciated.
