1955 johnson jw-11 prop part # ???
warrenjets
So im trying to get this old seahorse running and i noticed that the prop was cracked. I looked around and im having a hard time trying to find the part number for the prop so i can order a new one. Its a two blade prop and a 3 hp johnson jw-11. thanks for everyonees help
warrenjets
Re: 1955 johnson jw-11 prop part # ???
Ah crap.. In Haste i ordered one off o ebay.. It was new old stock.. odd thing is its a reverse pitch propeller. I wonder what this thing fits?
here are the numbers on it. 300,560 and m 6 5/8 x 4 1/4. I sould of just called the number above to begin with.. (
lindy46
Heh Heh - well, going backwards won't be difficult, and you can turn the motor around 180 degrees to go forward!
kfa4303
Banned
I agree. You could just mount it on the bow like an electric trolling motor while you're at it too. That way you can still reach the controls and stuff. It would get you some looks for sure at the lake. That prop must be for a motor in the Southern Hemisphere, where everything spins backwards :)
warrenjets
does the two or three blade make a difference. Its going on the back of my canoe. I would like to keep it original if possible...
kbait
I've used both as kicker motors. I couldn't tell any difference 2 vs. 3 blade.
kfa4303
Banned
Ditto. I don't think it would make much of a difference one way, or the other, on a motor that small. My little 3 hp has a 3 balde prop, but I've seen much more powerful mud motors and the like with 2 blade props. I think the overall size, direction of spin and pitch are more important than the number of blades.
warrenjets
I wanted to say thanks. I got it running. New points. coils condenser and carb kit. Still havnt got a prop.. back to the parts diagram i go.
