Re: where to start?
Howdy and welcome to the drydock, wags...
Nice lookin boat.
Depending on what you are plannin to do to it, will determine where to begin...
Are going for the full restoration or just a cosmetic clean up?
Check the Johnson Engine forum for all the proper maintenance items to take care of, to insure a long and happy life for that motor...
Since you are already pretty sure the engine is in good shape, my next and biggest concern would be to look for wood rot deep down in the bowels of the boat...near the bottom of the transom and stringers...99% of all boats that are that old, usually have some form of wood rot...unless of course it was kept in climate controlled storage.
To check for the rot, you will have to take some core samples by drilling into those areas...if the drill comes out with nice light, dry, new looking wood shavings...you win and there is no rot...you can then seal up those core drillings with some PB[peanut butter, a thickened fiberglass paste], and move on...
More than likely your core samples will come out with what is affectionately known around here as 'Mulch'...dark, wet, nasty wood shavings, or maybe nothing at all, meaning the rotten wood has been washed away over time...
I certainly hope you are one of the lucky ones and find nothing but good clean solid wood, but if not, you are in the best place to find out all the info you will need to fix it...
Best of Luck,
GT1M
PS- kinda made it late to the response party, I see WOG got here while I was scribblin...:redface:
