Re: 1966 Evinrude 6hp Starter Unit
sweet. I used a bit of carb cleaner and a small wire brush to clean my water uptake screen and it worked great. Glad you got her running. The ol' rope trick works every time. Even the Big Twin motors of the late 60's had the notch on the top for pull starting in a pinch. The real old, antique outboard all started by using a rope. Check aomci.org for a fellow OMC nut near you Those guys are great and they will often sell/give you parts for super cheap. Happy parts hunting!
