Hello,
Saw something that I thought was worth a question. When I pump the bulb on the fuel line... I thought it should get to a point that it would no longer pump..(Hard)... but what i noticed was that fuel was comming out of the front of the carb from the top right side. There is a hole there and it just comes out. Now is this a problem with the float and shutoff valve internal to the carb, or is this normal? Cuz if I pump it while it is running, all sorts of sputtering happens...
Rebuild or not to rebuild????
Thanks in advance...
Michael
Michael
