Re: Force 125 bypass valve
When used, there were basically two different systems for the bypass. The only difference was from where the water was bypassed.
Water is delivered to the bottom of the block. Just above entry it passes into the water jacket. Now, in the old style bypass there is a hole drilled from the entry point through to the plastic valve plug. When the thermostat is closed, excessive pressure forces the plastic plug open and water passes down a square cast-in hole that exits right by the exhaust downtube. In the newer system, the drilled hole between the entry and plastic plug is not there. Instead, the water jacket has a separate small chamber at the bottom which is drilled down into the valve chamber. Now, when pressure get high, water will again force open the plastic plug and bypass down by the exhaust tube.
Later engines did not have a bypass at all. The reason: When the water pump pressure gets high, the vanes simply bend and bypass anyway-- that is a characteristic of centrifugal pumps.
Back to your engine---You probably have the newer system. Clean the lower chamber of the water jacket. probe the bottom of the block and open the bypass hole. Then drill out the old bolt and replace. If the block is not too badly thinned there, you may be able to tap oversized, but you should definitely be able to drill and tap deeper.
In the first photo, you can see the separate small chamber above the valve. Note that it is sepated from the rest of the water jacket by an aluminum web. In the second photo, the large hole is the water feed to the block, The smaller hole right next to it is blocked but is a drilled hole up into the separate chamber in the first photo. The bottom is blocked by the match plate gasket when the block is installed. Unfortunately, I did not notice it when I snapped the photo, but the rectangular bypass hole is hidden by the stud in the second photo. This is where the bypass water exits.
The bypass system is not needed and when plugged there will be a hot spot at the bottom of your block, but it should not harm anything. You could remove the valve assembly and fill the hole with epoxy.Then, drill a small hole in the web of the separate chamber so water will circulate through it.
