MotorheadTed
- May 2, 2011
- 50
I have stripped my outdrive to bare metal and am about to start repainting it. I am planning on first prepping with "aluma prep", then treating with alodine, followed by urethane primer and finally a urethane topcoat with hardener.
I had read somewhere that all pitting should first be filled. (I'm thinking epoxy, maybe JB Weld).
Anybody have any thoughts about this procedure, pro or con ?
Ted
p.s. I noticed that the top bearing retainer cap and the shift cover are made of a dark grey, blackish metal, probably magnesium. Can't imagine that would last 2 seconds in salt water !!! If it is mag, I think the prep chemicals would be different than for aluminum.
Anyone know for sure what that metal is ?
p.p.s. I am also starting another thread in the electrical forum re: corrosion on this drive.
Ted
