jgregory01
- Nov 25, 2009
- 53
My aerator just died. It gets juice, because the whole thing gets hot, but does not spin or take in water. It is an Attwood 500gph #4108 which is no longer made. I read other posts so I will not ask about the intake diameter stuff, I know they are difference sizes now.
Is there a chance that there is something stopping the impeller? Can I take a water hose to the intake valve, at the transom and force water into it and possibly free the impeller?
If I have to replace it, I am not an electrician and I am not very well versed in electronics. I have attached some pictures of my current set up as a reference.
For removing my current aerator, can I just tap it out with a rubber mallet or is there some retaining nut that I cannot see. I removed the retaining plastic nut that is on the outside of the intake pipe. It screws on and rests against the transom. When I removed it I figured the aerator would come out without much difficulty but no doing. Is it being held on with sealant and that is all? I can see some kind of white soft caulk looking sealent between the unit and the transom. It can barely be seen in the attached photo.
Second...the wiring. Can I just cut the brown/black wire from the original unit and connect the new wires without problems? I have shrink tubing and a heat gun. There is a nest of wires that are set behind other piping that I would prefer not to deal with. The photo is attached.
I guess that is about all I have. Thanks.
