I was wondering if anyone could tell me what years and other HP outboard evinrudes have the same heads as my 1979 115hp evinrude outboard does? any help would be much appreciated!! thanks guys!
Thayre going to be the standard 78-81 low compression head found on 90-115 powerheads. Ive got a pristine set I pulled off my 81 vintage 90 if you need some.
You can look up your own heads on the Bombardier parts catalog website: epc.brp.com. The 79-81 heads are still the high compression ones and are solid heads. Look for 125 lbs compression out of them. Much preferable to the later low compression bathtub heads. The 140 heads from 79 are even better.
