cjleger337
- Jan 31, 2012
- 4
I have a 1972 Johnson 6HP that I am trying to fix up to put on my 10ft aluminum boat. I can get it to start, but only for a few seconds. Here are a few issues I am running into.
I might add that I by no means am a mechanic, so you may have to dumb things down for me. I just break things down to simplest form, which is why I even got this far into the project.
-Oil/Fuel mixture coming out of the underwater exhaust. This is basically my main concern, does it indicate something major is wrong with this motor?
- Motor runs strong for a few seconds, then dies out when I turn the choke off. I have adjusted the rich/lean idle screw, but am still having the same issue.
If anyone can help me with this matter it would be greatly appreciated, I cant let this motor defeat me!!!
