Re: How to clean cooling system of 9.5 Sportwin
It was a little crusty and I used sand paper to clean it up. I have replaced the head gasket and water pump and she still runs hot. So I am guessing the water flow is not where it needs to be. It spits water but then it gets real hot and I have to shut her down. I put a new t-stat in as well. I will try flushing from both ends and see what happens.
Yeah that sucks that it is so blocked up man. Try shooting water into every orifice that you have. I shot it up the exhaust tube, into the coolant jacket (covering the cylinders), up the water input tube and all that mess. Mine was a salt water motor too. Fortunately for me though, some dummy didnt run it in sand and salt water and just say F it and let it all dry up in there. It was still pretty blocked up in there though. I ran a coat hanger little by little into all of the ports, and day by day let water and CLR soak deeper and deeper until I finally had free flowing water through the whole water system. Worked for me......
P.S. I actually like it that these motors have the exhaust water exit from so up high. Lets you know that you are DEFINATELY flowing water, unlike the newer 9.9's that have the thermostat after the telltale hole, meaning that if the thermostat seizes up you still flow water from the telltale.
