- Oct 25, 2011
- 25,306
I have a 1971 long shaft 650 Merc. I've been looking for a short shaft version but have only found long shafts anywhere close to what I can afford, or anywhere nearby. In my search, I've found another long shaft '74-76 650 w/ a blown powerhead. Are there any parts that are interchangeable w/ my '71? I'd be interested in the blown motor if I can use the lower unit on my 650. It'd be worth the asking price to have a spare lower.
I know of 2 4cyl short 650's 1 runs (maybe, haven't seen it run), 1 ???, but both are 6+hrs away. W/ cost to go get 'em, and go through 'em, I'm hesitant to take the plunge on either. Plus w/ the 1 boat in dry dock, thread in my signature, the possibilty of a 2nd boat pending, 1972 Century Raven O/B w/ running motor.
In my resto thread there has been some discussion about raising my transom, but I'd rather not.
Are there other years, models that fit my 650? I tried to find a thread that mentioned changing to stronger lower unit that had taller gears(?2.3 up from 1.6?). Apparently it had stronger drive gears then a mid 60's 650. But I can't seem to locate where that was mentioned. Can anyone confirm that, w/ years & models?
My FireFlite is rated up to a 75hp, so I could also be persuaded to move up to a larger then 650 motor if it would also be easier to find the short shaft version.
I will probably leave the transom where it is, and use this 650 as a long shaft, unless I can put together a different setup w/ alternate years & model parts.
Thanks
Thanks
