Brian Earl Anderson
- Jan 30, 2012
- 2
Hello all.
I'm working on re-carpeting my 15' Foxcraft bass boat. I just have a couple of questions about the install:
1. I am worried about the casting decks. I have the carpet rough cut already - allowing myself about an inch overhang all the way around. Everything I have read says to glue the carpet 1st and THEN cut it. The carpet does lie in a recess all the way around on both decks. However, their are many rounded corners to deal with. The "lip" all the way around the recess area has a rounded radius, and I'm worried about my blade wandering around within that radius while I try to cut. Also, all the cutting I've done thus far has been on the backside of the carpet - I'm just a little afraid of the unknown when I go trying to cut from the face side of the carpet.
Has anyone tried cutting the carpet before gluing in a situation like this? I know it would be a pain, but I am sure that I could make up a good template to cut from. My fear of this idea is that the carpet might stretch a little as I glue it and roll it out - leaving me just a "skoosh" to have to try and cut off which I believe would be much harder than than the inch or so I have now.
If I go the route of cutting after gluing, is it advisable to wait for the glue to set up good?
Suggestions?
2. That darned glue! The glue I have, and the directions on all the other ones I have looked at says I have to maintain 60 degrees during the install and 48 hours afterwards.... That's a tall order in January - even in Texas. We're not up for a freeze the next few nights, and 60 degrees during the time of install is not a problem, but it is getting down into the 40's at night. My question is - Can I go ahead and proceed with installing during the day when it is 60 or above, and just know that the cure time will be longer? I was very diligent during the prep process and don't want to have to do this again.
Thanks,
Brian Anderson
Suggestions?
Thanks,
Brian Anderson
