I am having continual battery issues on the starting motor battery...I have replaced the battery and it is not holding a charge...I can run the boat for about 3 hours and then I will probably have to jump it off to start the boat...Is there a fuse relay for the stator? and what voltage or ohm reading should I get when I check the stator to see if it is charging?
Thanks
Thanks
