Carb Problems?
eastert
I have a 1984 mercruiser. It idles just great. If I try to accelerate, the engine bogs down. I have tried to adjust the idle mixture screw, and can make a difference, but can never get it to run well. At most I can get 3000 rpms. I have changed the fuel filters and drained the tank.<br />Do I need a carb rebuid?
oxbowman
Re: Carb Problems?
When did this problem start? Did you check points or corrosion inside the distributor cap?
eastert
Re: Carb Problems?
I changed spark plugs and points, but did not check the distributor cap for corrosion. Could this be the problem?
Re: Carb Problems?
Possibly,.....<br />But, I'd be looking at Rebuilding, or replacing the Carb........<br /><br />BTW,.......<br />Why'd you do just a Half A$$ed Tune-Up..???<br />I mean,.. You had the Dist. Cap Off to replace the Points,..... And Didn't Even Look Inside the Cap..???................ :rolleyes: <br />How about the Points,...... Did you set them by Eye,.. Or use a Dwell Meter ????
