Arctic 33
- Oct 30, 2011
- 42
I took the boat out a couple of weeks ago and dialed in the high speed and low speed. Boat ran great. Went yesterday
and the motor started but seamed to be starving for fuel. It seamed the fuel was pulsing. Alot of sneezing. The primer
bulb did not want to push down. I moved the low speed setting a little it did not change. When I returned home
I pulled the assembly from the tank and the primer button is now functioning. There was pressure in the tank when I
removed the cap. I put in a barrel today and it started fine and was still pulsing and sneezing. I moved the low speed
out until it leveled out and was idling good. This was about 1/2 turn. Started the motor a few times and the idle was good.
Then it would start sneezing and the level out. I started the last time and it idled 5 minutes no sneezing, i removed the
fuel connector and the motor died in about 5 seconds. There is always pressure in the tank. Wife wants to go fishin and I
don't need it to let her down. I think I am missing something. Could the primer button being stuck cause my problem.
After running so good a couple weeks ago I thought this seamed to be a strange ocurrence. It seams to be running fine
now.
Thanks
Chuck
now.
Thanks
Chuck
