Honda BF130 fuel filter list?
c-level
I'm getting ready to change out my fuel filters and am trying to get a filter list. The fuel/water separator is a 60 GPH Racor Fuel/Water Replacement Element 17670-ZW1-801AH. I also saw two filters under the cowling that come directly from the gas line. One of them said "Taiyo Giken R27" and had the in/out fittings on the same side, I cannot figure out what is the replacement part for this filter. The other was below that and had the in/out at a 90 degree angle, I'm guessing it is similar to a Sierra Fuel Filter (Honda) 18-7720?
Does anyone have the part number/type for these two inline filters? I've seen a billion of them online and can't figure out which ones to order and the Honda Manual does not list them either. Thanks!
Flakeys
Re: Honda BF130 fuel filter list?
The 1st one is the LP filter p/n:16900-SR3-004. The only other fuel filter is the HP filter located in the Vapor seperator. That p/n is: 16911-ZY3-000 and you also need the o-ring p/n: 16078-ZY3-000.
