I have 2 observations to get input on. The first is I pulled all the plugs and noticed 1 plug out of the 6 was completely clean. The other 5 were wet as in normal. I checked this 1 plug to see if it was firing and it was. I did a compression check of the cylinder with this plug and it was 100psi. Checked the others and they were 100psi as well. The location of this plug was the cylinder with the highest carb. I dont have VRO. I mix the gas and oil.
Next, I notice one side of the engine gets hotter than the other. And the cylinder with this very clean plug is also cooler than the rest when idling in the driveway with a garden hose. Does any of this sound strange? What should I inspect?
I appreciate the responses!
