120 hp vs 3.0 outdrive
jimg984
friend has 1985 cris craft with a 3.0 mercruise outdrive with no engine when he got it....we are looking at a120 hp engine and not sure it will connect to outdrive.... need info bad,,, ths
Re: 120 hp vs 3.0 outdrive
Ayuh,... The 140hp,3.0l, 'n the 2.5l 120hp motors both have the same bolt holes in the same places, in the same sizes...
Easy swap....
jimg984
ty for your quick and simple reply... will the splines from the 3.0 outdrive match up with clutch splines on the 120, because he doent have the fly housing that was with the 3.0 outdrive.......pervious owner of the 3.0 let that go with engine ty
Silly Seville
Yes, the Alpha 1 input shaft splines will match the splines of the coupler of either the 120 or 140 engines.
achris
More fish than mountain goat
The only difference between a drive for a '120' and the drive for the '3.0' is the label on the back. EVERYTHING ELSE is the same, including the yoke splines, and the ratio.
Fishermark
I know you didn't ask... but just be aware that you will notice a big difference in performance. My father had an 18' Sportcraft which performed well with the 3 liter it came with. When that engine died, he replaced it with a 120. The difference was amazing - in a BAD way. If your main goal is simply to get from point A to point B, then yes, the swap will work. Just don't expect much in the way of performance.
jimg984
ths for all the replies,,,, i welcome all input,,,,,easier to type than work, even with my bad spelling
