Re: Adding another battery to my 10 Q8i
I added another battery to my Q7i and it wasn't hard. As for mounting, the second battery fit right behind the first one. I have had this in place for about 2 years, and haven't noticed any adverse handling from the weight of 2 batteries on the same side (in case someone mentions this). You will want to look for a battery switch, I used Perko but there are other makers out there. You should be able to get a battery tray from West Marine (or other marine store) to mount the battery on, so that you can strap it down so it doesn't move. After that, I mounted the Perko switch to the inside of the engine compartment and wired it up, it was really quite easy. The only thing to remember is that the alternator on the boat won't be able to charge both batteries at the same time, so make sure that you never set the switch to 1&2. Good luck with the install.
