I have been messing with some wiring due to motor not starting with ignition switch. Finally, I replaced the battery cables and solved my issue. Today, I tested out the new cables and was able to get the motor started. I was feeling pretty good since I have always had to pull start it since I have had the boat. I turned the key off and the motor kept running. I unplugged both battery cables and it still kept running. Finally, I unplugged the gas and a few minutes later it ran out of gas and stopped. Not sure what the problem could be. Any ideas would be greatly appreciated! Boat also seemed to be slightly in gear. I jiggled throttle, appeared to be in neutral.
