Re: Fuel tank access on older KW boat
Yep, my brother-in-law's 19' Key West got a bunch of water in it's 60 gallon polyethylene tank, screwed up the injectors, lots of trouble, they removed the T-top and center console, cut deck, removed old tank, replaced with a 40 gallon aluminum tank with a welded-in drain line, stainless valve, stainless pipe plug, drains to bilge, not transom. Doubt it's coast guard approved, but should be easy to drain water in the future! Somebody should design and build a built-in tank flush/pump/tank unit for this application!
