Airslot F21
- Jan 24, 2012
- 6
I am replacing a raw water cooled MCM 228 (with pre-alpha drive) to a full closed cooling MCM 250 and Gen 2 Alpha drive. I operate in salt water, the boat is a 1976 Wellcraft F-21 ("Airslot"). The "new" (lightly used) engine previously used blocking plates for the drive mounted sea water pick-up and a thru-hull for the belt driven pump. When flushing the engine, Mercruiser specifically recommends using two hoses, one at the drive and on for the ilet side of the belt driven pump. I am considering modifying the system to provide drive pump water to the inlet side of the belt driven pump, in addition to (and upstream of) the thru-hull. It seems as though this would allow for shutting off the thru-hull and allowing the drive pump to provide the entire system with sufficient flow when flushing, using only one hose. My question is whether the belt driven pump would potentially push water backward through the drive pump when under way, (is the belt driven pump a higher pressure pump or just higher volume?), and if so would incorporating a positive shut-off to the drive pump work? It just seems like a huge pain to figure out how to get flush water to the thru-hull, drag two hoses to the boat, etc. Any thoughts?
