boatingguy
- Jan 21, 2012
- 11
So after determining that my fuel pump was bad, I purchased a replacement called out in the parts manual. Upon arrival, I also discovered that the one previously installed on my starboard engine was the wrong pump. Someone cut off my original connector and installed one for that pump. I'm starting not to like old boats and the previously done maintenance...
Real question - where can I find the correct connector without buying an entire new wiring harness? This is the inline pump on the 4.3 that has the connector on the pump (not pigtailed, but directly on the pump). I need the one on the boat as shown in the attached photo (at least I think I attached the photo). This is the one that would attach to a "805656A 5" Fuel pump.
Any help on where to find this connector would be appreciated.
