harbor freight trailer led light kit???
cpubud
Re: harbor freight trailer led light kit???
I have 2 sets on trailers and no problems for almost 2 years now.
120_i/o
Thank You, Im sold!!!:D
smokeonthewater
absolutely top notch for the price..... you couldn't get em any better anywhere else for 3 times the money..... I've installed close to a dozen sets on various trailers, both square and rectangular sets
i use the magnetic light from harbor friend i can switch them from diffrent trailers. and take them off when i back into the water.
cribber
If you're going to permanently mount them pop for the extra 5 bucks and get the submersible kit listed above.
lckstckn2smknbrls
The lights from HF are good it's the wiring I have found to be sub-standard.
Silver Eagle
Master Chief Petty Officer
Last year I got a set of Submersible lights on sale at HF for $19.99 I had then put on at the marina I got to and so far they work perfectly. I think the secret is to let the trained experts do it.
120_i/o
Thanx for the tip gang!!! I will get the submersible type as indicated before, and I should be good. The wires on the trailer are good, so not much to mess with. Thanx again.
120_i/o
I may go this route instead, thank you!
