Re: Johnson 70hp lower unit question
Silicone should NOT be used anywhere on a outboard engine, BUT this would not be the cause of water entering the lower unit.
The usual cause of water entering the lower unit is either having fishing line becoming entangled in the propshaft seals, OR the top driveshaft bearing becoming worn slightly which would allow the driveshaft to wobble ever so slightly, but just enough to allow water to enter the unit via the seals in that housing, OR simply having no nylon, fiber, or O Ring type seal on the drain and oil lever screws (whatever seal might be required).
(Checking Gearcase For Leaks)
(J.Reeves)
Remove the large slotted drain/fill screw from the bottom of the gearcase and also the identical looking screw that will be located up near the cavitation plate in order to drain the gearlube.
After all of the lubricant has drained, install one of the slotted screws, whichever your preference might be.
Apply 7 to 12 pounds of air pressure to the open screw hole. Use a piece of rubber fuel line or something to create a tight air hose fit if you do not have a proper fitting.
If a leak exists, that pressure should allow you to locate the leak by sound and/or sight.
