Re: Is fuel injection a good thing on these VP powered boats?
I have experience with programmable EFI in both automotive and now marine, so I can speak from experience, not just theory. My systems are all speed density, late '80s early to mid '90s technology. I can't speak to any technologies newer than that. Newer technologies are better, but for back yard enthusiasts like myself I am limited in my tuning resources so that's what I stick to.
A well tuned carburetor and conventional ignition system can come close to the degree of tune that you can achieve with this older EFI technology. The key here is "well tuned". Few non EFI installations are tuned to this degree. The fact is that if you are capable of fine tuning a conventional carb and ignition system, tuning EFI will be a much easier for you with the added advantage that you will have finer control. Neither of these options are for casual tinkerers. It takes a lot of time, knowledge and dedication to make even small improvements, but that's kind of the fun of it all.
Getting back to the original post. There is no doubt in my mind that EFI can control an engine better than conventional carb and distributor. The downside to factory EFI is that you are now "held hostage" by the Original Equipment Manufacturer as far as diagnostics and repairs are concerned, but no more than if you were to buy a new automobile. It's just a fact of life with more complex technology. If you don't have the ambition to tackle programmable EFI, but still want the freedom to work on your own iron, then sacrifice a bit of performance and go with the old stuff. It all works, just to different degrees of precision.
