2 way radio
angler00
looking for a new 2 way radio dont know if I want a handheld or dash mounted, right now I have a dash mounted..
what are pros or cons with both?? input would be appreciated
halfmoa
Ensign
Re: 2 way radio
Well I don't have any experience with the handhelds but I can tell you I've never dropped a dash mounted radio in the water...
angler00
Re: 2 way radio
true... with the electronics today just want to see what my options are.
will be replacing all electronics on the boat.
just got a lowrance elite 5 gps for it
NYBo
Re: 2 way radio
Fixed mount:
Pros:
+Higher output power (25 watt vs up to 5 watt), which helps receivers lock on to your transmission when there are competing signals
+Connected to a longer/higher antenna, which increases range (although you CAN connect a handheld to such an antenna with the proper adapter)
+It's mounted to the boat so it's hard to misplace it
Cons:
-Relies on boat's electrical system, so if that system fails, you can't use the radio to call for help
-You can't take it with you if you have to abandon ship
-A suitable mounting spot may be a problem in small boats
Handheld:
Pros:
+Self-contained unit, independent of external power and antenna; some even have GPS and DSC capabilities
+No issue with mounting
+You CAN take it with you if you abandon ship
+Most float in case you drop it overboard
Cons:
-Lower power
-Shorter/lower antenna (unless hooked up to a boat-mounted antenna)
-You have to remember to keep the battery charged
-Easy to misplace
I like redundancy, so I have both.
