strawberry
- Sep 14, 2011
- 12
I bought a used 18 foot allweld wide flat bottom boat to restore and use in skinny water. I put a short shaft Mercury 70 hs motor on it. It had the tunnel welded closed and i took a grinder and opened it back up. The first time i tried it at the lake it cavitated so i adjusted the engine a bit more forward ( or down at the lower end ) and it helped some. I had my partner sitting in front of the console and when I had him move just back of me the boat planed out and ran about 10 miles faster. It did dig deeper into the water in the back though. When I cut out the tunnel I left a bit of a lip at the entrance to it because the fuel tank is right above it and i did not want to take the chance of accidentally cutting all the way through and into the tank. The lip is about 1/2 inch out into the cavity and may be diverting the water back instead of sucking it up into the tunnel. I just don't know what else it might be. Can any of you enlighten me on what might be the problem? Also when i had the engine tilted up a bit the water was not getting to the water pump inlets. With it tilted more down it does get water to it but not as much as it should, probably because the tunnel is not full. I don't want to change the center of gravity by moving the console back until I rule out the tunnel or something related to it out. please help. All comments will be appreciated.
Thanks
Strawberry
Thanks
Strawberry
