I have an 88 OMC Cobra and the trim sender arm is never contacting the outdrive or whatever is supposed to be moving the arm and triggering the sensor. I can move the arm manually and the sendor works sending signals to the gage that works correctly. However, as if I run the trim the outdrive never contacts the arm. I purchased a new sender assembly, installed it and the same issue exists. At this point, I'm guessing there is a part that should be attached to the outdrive that would contact the arm. Is this correct? If so, can someone point me to the part number and a diagram that shows it? I haven't been able to find one... If this is not correct, what am I missing? It seems like an fairly simple design...
I purchased the boat a few months ago and this issue existed at that time. I have no idea when the problem developed.
Thanks!
Thanks!
