1976evinrude
- Apr 11, 2011
- 77
Well I finally found a replacement lower unit for my 1976 evinrude 85hp and need help with the installation and water pump/thermostat. My questions are before I install the lower unit I found I would like to make sure the cooling system on it is functioning properly. I already ordered the water pump rebuild kit , but my concern is the thermostats if it even has one. How would I go about servicing them, where are they? Any pics would be great!
My other question is when installing the new lower unit are there any gaskets or seals that I need to replace? Or can I pop the lower unit off the parts motor and just pop it back onto my motor without any sealing or gaskets todo?
Thanks so much!
Thanks so much!
